  • 15 Replies
  • 8763 Views
  • 2 Likes
  • 6 In Conversation
Murray4750
I was wanting to place my camera outside. I now read that you can only leave the camera plugged in if it is inside. If that is the case your information on this product is defective? Please advise.
Also bought two outdoor mounts. When I go to mount these they have to go in an outside wall which is accessable by the public. The mount allows for the easy removal to I imagine charge the battery. How could i make the camera more secure?
15 REPLIES 15
Dannybear
To prevent easy removal you could attach a short lanyard to the wall. If you’re using the magnetic mount or the twist on mount it would also protect it from falling if it gets wacked although makes little difference if it is with a baseball bat. Best option is to relocate to a location out of reach.
Murray4750
I have spoken to your support staff. They now tell me that the cameras have to be within 25 feet of the base station? is this correct. I want to try this at my location how do I do this.
Not sure what your referring to..., but if syncing the cameras must be fairly close.
Ive found less than ten ft always works.
If you mean operate, not true.... I have several that are 40+ ft away and work fine . It really depends on what the signal goes thru and the signal level at the camera.
In a test, clear line of sight, I exceeded 300 ft ( tho not real world usage )
As a PS,  there is an outdoor ac cable available if needed AND and external mounts
See accessories under products at top of page
Outdoor Power Adapter for Pro, Pro 2 Model 4900
PPS any normal camera mount will work...the threaded hole is standard 1/4-20
brh
@Murray4750
As far as power is concerned, if you do not mind climbing a ladder every so often to change the battery with a fully charged one, you can operate the camera solely on battery power. The other option is to use a solar panel if possible so that you can mount the camera higher up to discourage theft.
Brian
Murray4750
Have found a very good waterproof lead and metal mount with chain on Amazon. The very good extra arrived here today in less than a week to NZ. Fantastic. Thanks for responses.
Murray4750
See previous Email. Found a sturdy solution on Amazon. Super delivery on metal mount. and chain(looks good too,) There is also a weather proof extension wire that looks like it will seal well for out door use and allows extra features available for plugged in Arlo cameras. Thanks
Murray4750
Have good connection on outside connections at both ends of the House. Didn’t need to worry.. will just need to learn how to reduce sensitivity on motion sensor as they are now picking up leaves blowing across the scanned area..
Murray4750
Problem now solved. Good reception. Needed to just go through the procedures properly and reception is fine. Thanks anyway
Dannybear
Any chance of a photo of the mount and chain, would also be nice if you could detail the products used so we can take a look at using the same.
Murray4750
This is the details of the mount that I bought. Photos available on Google. Sorry cant send the link or photos through this system. Holaca Security outdoor mount for Arlo Pro 2 with anti-theft chain.
Xnavyman17
I have one inside and it works fine not plugged in.
Murray4750
They all work fine indoors and now outdoors but I was wanting a more secure fixing against theft and the extra features that are available when plugged in. Also have the cameras mounted high and it will be easier if I want to change batteries etc easy to get the wire into two places out of three. Thanks
Murray
Dannybear
@Murray4750,
Thanks, I have attached a screenshot of the mentioned mount as an example of what has been discussed.
Lightyears
What I did was built little bird houses to hid the cameras and also I can run the cable through the back so they are always plugged it
  • 15 Replies
  • 8764 Views
  • 2 Likes
  • 6 In Conversation
