Arlo Pro 2 cameras disconnecting at 40% battery.
So for about the last 3 months my Arlo pro 2 cams have been disconnecting from the server when the battery reach around 40 as if they're dead. When I plug them in to charge they read around 40% sometimes higher.
I've relinked all inside the house next to the homebase multiple times but it's still happening.
Beyond frustrating especially when not at home.
Any Ideas??
Thanks!
# https://www.arlo.com/asia/cameras/pro2/VMS4430P-100NAS.html
Did you check to make sure the cameras have the latest firmware update? Also does the base station?
What I would do is try to factory reset one of the cameras and see if this corrects the issue. If not doing a factory reset to the whole system can help correct issues as i've seen in the past.
