Arlo Pro 2 blurry picture
Just installed my firt Arlo pro 2 camera outside. The quality is set to "Best" but it´s not that good i think.
It´s quite blurry and when i zoom the picture it gets even worse. Is this as good as i gets?
Base firmware is 1.14.0.2_2777
Cam firmware is 1.125.13.0_31717
Hi!
I run the camera with a poweradapter so i have not tried best battery life mode.
Regards
Robin
Thanks for that info. From my perspective, the quality does not seem very blurry. Do you have a comparison screenshot by chance?
You may try and reboot the base station and/or camera by removing > Re-inserting the battery and test again.
