Arlo Pro 2 battery life
I bought Arlo Pro 2 in January. After fully charged, the batteries of the two cameras had lasted for almost 3 months. However, for the second time full charged, the batteries could last for about a week. Why does the battery power run out so fast? This problem happens to my both cameras.
There were some glitches in the last round of FW updates, I would check to make sure your running the latest versions of FW and recharge the cams and test again. ( shouldn't be happening )
As a PS to above....
the main reason there is an off setting for the camera is privacy. When the cam is OFF, shared access is disabled and it will only respond to the primary owner ( who can turn it back on )....there really is no power savings as compared to Disarmed.
Only really recommend use for privacy.
