Arlo Pro 2 - basic concepts
i'm figuring out that you can not get motion notifications saved to library when using cvr. you can have continuous recording or motion detection. is there anyway to get both at the same time?
It's being suggested that removi g the camera frrom Smart allows this to work. Try that and let us know.
tr0055,
The development team is currently investigating reports of this issue. I will provide an update as soon as I know more.
