Hi Community
N00b here so apologies if this has been answered elsewhere - I couldn't find it.
I have the VMS4330P system and I have wondered, if someone breaks into my house, and steals the base station, my cameras go offline. Can I still access the footage? Or do I need to replace the base station before I can view it?
You should be able to acess the Library files via an app or the browser even if the base is offline. ( or gone )
If you want to test this, you can easily unplug you base and then view vids... tho the app/prgn will say they are offline library access is still there.
