I currently have a Arlo Pro base and camera now. I want to buy just the "Add-on camera". Will the Pro 2 be offered for sale of only the "Add on" camera without the base? Currently I only see it offered with base and either 2 or 4 cameras.
Thanks,
Dale
I found it as an add on camera on Amazon. A search for "arlo pro 2" didn't return any pro 2 hits but the part number for the 2 camera kit (VMS4230P) returned a pro 2 hit and then from there the add on option was available.
https://www.amazon.com/NETGEAR-Security-Rechargeable-Wire-Free-VMS4230P/dp/B075P84FH9
If you look at the buying options on the page, scroll down and you will see it as an add on (a bit confusing) listed under accessories with a MSRP of $219.00. @JamesC
Thank you both for the info and for the link. As you said, I had searched for Arlo Pro 2 and didn't find it.
Glad they will offer it alone.
