Arlo Pro 2 Won't Register Movement
  • 1 Reply
  • 1267 Views
JGelston
I have 4 arlo pro2 cameras. I've had them for appx 6 months. About a month ago 1 of the cameras stopped recording movement. It would go live when prompted to though.
When I took the camera in, I removed/replaced the battery and it worked just fine for about a week or so. This has happened about 3x in the last month. It'll work fine for a week then stop recognizing movement until I remove/replace the battery.
I've increased the sensitivity but that doesn't seem to help.
Any thoughts?
ShayneS
Have you tried to reboot the base station/remove & re-sync the camera and test again?
  • 1 Reply
  • 1268 Views
