Arlo Pro 2 With Mobile Router Nighthawk M1 (MR1100r0): Batteries Drained In <24h
  • 26 Replies
  • 10340 Views
  • 3 Likes
NeuFred
I'm using 2 Arlo Pro 2 with the Netgear Mobile Router MR1000 (also called Netgear Nighthawk M1) which has an internal Arlo Base Station. The recent installation and sync worked fine and I can watch the monitored scenes. My big problem ist concerning the batteries which are draining within <24h. I rebooted the router and recharged the Arlo 2-3 times during a whole night and can not notice any increase in the autonomy of the batteries. The cameras are less than 10 meteres distance from the router and the signal is strong. I also checked the latest firmwares on router and Alro ... I set the battery optimization to "optimized" ... nothing helped so far ...
In comparison I also have another installation in a second home with the Arlo Base-Station (VMB4000) and one Arlo Pro 2 and this works fine, sufficient autonomy ... nothing to complain about.
My theory : is the Mobile Router the source of my problem ? Has anybody experienced Arlo with this Netgear Mobile Router with Arlo Station integrated ? Shall I activate the warranty of the 2 draining cameras batteries ?
Thanks for any suggestion or advice !
Cheers, Rick
26 REPLIES 26
NeuFred
Update from my side : I installed my 2 Pro 2 cameras on a base I bought "behind" the MR1100 router (without activating the built in Arlo base) and see there, the cameras work perfectly, don't drain within 24h as before. My work-around solution works and my conclusion is not to use the Arlo-Module in the MR1100.
AncientGeek
Hero
Hero
That is great to hear.
I would definitely recommend that solution for permanent installations.
  • 26 Replies
  • 10341 Views
  • 3 Likes
