Arlo Pro 2 Wall mounts. Any way to "fix this camera on wall" so no one can steal?
  • 2 Replies
  • 1367 Views
Mrnicoo
Is there anyway to "Fix this camera in the wall" so no-one can steal it? As I understand there is just magnetic wall mounts or? I gone install this outside in Cambodia and they will probably steal it the same day....
AncientGeek
Hero
Hero
It sounds like you should research vandal resistant cameras.  Arlo does not have cameras that are intended for those situations.  Even the "fixed" mounts are just screwed on and can easily be removed.
I know Axis makes a lot of vandal resistant models, but none that are wire free.   Here is a link to one of their models, but it doesn't include audio and requires POE.
https://www.axis.com/en-us/products/axis-m30-series
AncientGeek
Hero
Hero
Here is a chart on vandal resistance ratings.  Aslo a link to another vendor site on this topic.
https://reolink.com/vandal-proof-security-cameras/
Vandal Resistance RatingsVandal Resistance Ratings
  • 2 Replies
  • 1368 Views
