Arlo Pro 2 Video streaming
  • 4 Replies
  • 2209 Views
gsr1379
With the option of using a Fire stick to view live video. Can I have it on 24/7 stream? Example if I plug fire stick in to a monitor can I have a constant view of what is going on. Also is there a some way I can 24/7 stream on a PC?
If this is possible, Could I have it on to two sources at same time (2 fire stick or PC and fire stick or 2 PCs etc?)
24/7 is only available via CVR when plugged in.
gsr1379
So it can only record 24/7 Not able to be viewed 24/7?
meier3283
Interested in the answer as well.  So, if I can live view my cameras on a PC/FireTV, does it ever time out?
As noted here before, the P2 cameras stream 24/7 when plugged in. That gets you the 3 second look back feature for your recordings.  If you want to see the whole stream, you must subscribe to the CVR option.  While this gives access to the 24/7 stream, the interface will time out at 30 minutes by design.  I haven't tried viewing CVR for long periods of time so can't say whether that will still time out as it will with live view.
  • 4 Replies
  • 2210 Views
