Arlo-Pro-2-VMB4000r3-base-station-not-working
  • 1 Reply
  • 1220 Views
Angelic491
Is this model still supported? The cameras stopped working.  Can you reset token?
DannyBearAgain
My pro2 setup is still functioning ok at the moment.
Others have reported mysterious issues with their systems such as the Base going offline but still communicating, cameras disappear from accounts, modes not changing the camera operation.
Some have succeeded in rebuilding the system from scratch only to have problems return days later.
You can try the same, remove all devices from the account, factory reset the base station, add them all back again.
The token reset is for HomeKit activation.
DannyBearAgain
  • 1 Reply
  • 1221 Views
