Good Morning,
I am Residing in South East Asia and my uncle from the states wants to buy me a Arlo pro 2.
I want to ask if the unit and cameras will work here in Malaysia? our voltage is 240v.
1. If i have a arlo pro base unit already can i link the arlo pro 2 cameras? and charge the camera with the adapter which came with the arlo unit i bought here?
2. The US unit Arlo pro 2. if i switch the adapter for that of the US one. will i be able to power up the unit instead of destroying it due to the voltage difference?
3. Or is there another way to workaround if the above doesnt work? besides a transformer which is what i dont want to use.
Thanks would appreciate any feedback and good day to you.
GriMmiE
GriMmiE
Yes the Pro 2 will work with the Pro base.
All power supplies are multivoltage so no problem with 220v.
You just need a USA to SEA adapter.
Thank you kind sir. i appreciate it.
