  • 12 Replies
  • 25549 Views
  • 5 In Conversation
Zoobz
Camara picture on 1 camara is gone all wavey and distorted
It still records still sends me notifications the microphone is working but picture quality is suddenly gone wavey
Any suggestions please
12 REPLIES 12
Streak2
Master Master
Remove and refit the battery to reset the camera. Hopefully that does the trick.
Dannybear
If your camera is smearing video, try going into the camera video settings and toggle the camera rotate 180 deg option to reset the camera’s encoder.
Zoobz
Ok just took the battery out and reset the camara let’s see if that helps
Thank you
Zoobz
Ok just checked my notifications this morning picture recording is distorted and wavey so battery remove didn’t work
Zoobz
Ok going to try this experiment to see if it works
Zoobz
Ok done the rotation but still having problems
Also done a reboot but still no luck firmware up to date
It could be a bad camera but first remove the camera from Settings, My Devices. Remove and insert the battery. Resync the camera and test. If still bad, open a case with support:
Zoobz007
Just spoke to support they said delete the App then reload the App log in then do exactly what you said
Remove camara and battery from device and then re sync with the base thanks let’s see what happens
Zoobz007
Ok good news issue resolved
Thank you
Zoobz007
How do I put a tick on this topic to say issue resolved
Go to an appropriate post in this thread and click on "Accept as Solution."
Zoobz007
I am on the thread but just can’t find
The solution resolved
I have checked every where
  • 12 Replies
  • 25550 Views
  • 5 In Conversation
