Arlo Pro 2 - None of my cameras are charging.
  • 2 Replies
  • 707 Views
KLynn913
None of my cameras are charging.  I have reset things, tried all batteries in all cameras
are you using the original adapter and cable....?
if so, maybe the adapter or cable is bad.
the Pro2 should charge on a 5v usb with at least 1.0a output. ( pro 1 def needs the qualcomm dual voltage charger )
Dannybear
Are you using the arlo web portal with browser? If so can you compare the battery icon status with the arlo mobile app version?
  • 2 Replies
  • 708 Views
