Hi! I bought a new VMB4000r3 - Arlo Pro 2 , 3 cam set, and I’m trying to set up the automatic alarm tigger on movement in one area, but there is no button for this in the mode area. There is only ( If motion then 1.Do Nothing or 2. Record Video.)
I have an Arlo 4k in another place and I’m able to do it there. I thought the Arlo Pro2 had this feature also.
After creating a camera rule within the mode you can add another device within that rule which should be the base siren.
In your rule, choose Add Device to add the siren.
Solved, Thanks
Got it. The error was that I was selecting a camera as the new device but it has to be the base.
Thanks!!
Thanks!!
