Arlo Pro 2 - Help Connecting To Iphone
  • 1 Reply
  • 1639 Views
daphne1028
I just purchased the Arlo Pro 2 and I have it set up through my computer but it won't connect to my iphone! How do I get it to connect if it says No Arlo devices found?
AncientGeek
Hero
Hero
If you have the system all set up through your computer, I believe you should only need to download the app and login using the same account you used on the computer when you set up the system.  The cameras should show up after you login.
  • 1 Reply
  • 1639 Views
