Arlo Pro 2 Geofencing not disarming
Hi!
The context:
- My GPS is always ON on my Samsung Galaxy S8.
- I select the Geofencing mode and a large radius.
- I lived alone and my phone is the only device connected.
The problem:
- When I come back home, it takes too much time to the system to be disarmed.
- I received a ton of notifications because I enter and move inside while my cameras are armed.
- Sometimes, the system disarmed itself, other times, the system doesn't disarm at all.
- Other times, the application logged me off, so I know that I need to log in to disarm the system.
Solutions I tried:
- Update the application
- Changing the radius from small, medium, large.
- Reboot my cellphone
- Turn off/On the GPS
Have you experienced this problem? What are your solutions?
I believe this is a known bug in the Arlo software. I have had your problems but also have had the problem of the system disarming when I reach my home area then immediately rearm itself.
Brian
