I am sure this has happened to others.... My Arlo Pro 2 fell off the mount and now it does not work. I tried to trouble shoot it.... I deleted it from my base station, reset the battery. When I try and sync it with the base station, it flashes Blue and Amber continuously, for 24 hours. It never stops doing it.. It will do nothing else but flash Blue and Amber.
Is this pretty much a "dead" camera now. It just will not work no matter what I try and I have had it only 6 months. Is there an option to repair it?
Any advice would be helpful and appreciated.
Contact Support for a replacement.. It's within 1yr warranty..
I contacted Support and they replaced my camera. Thank you for the great recommendation!
