Arlo Pro 2 External Trigger To Usb
  • 1 Reply
  • 1366 Views
brucebedwell
I want to get a trigger signal from the Pro 2 to enable an external relay or WiFi power outlet to turn on a spotlight. Any suggestions?
Why not just use a PIR floodlight... they are common/cheap and work well.
Or if really a tinkerer, you might be able to use the output of the siren to trigger a circuit.... AND/OR  there is always something in IFTTT format
( may void any warranty if case opened )
  • 1 Reply
  • 1367 Views
