Arlo Pro 2 -Enhanced controls after recording starts
Is it possible to allow enhanced trigger menus that are used during a recording so that...
1) We can capture people walking into and out of shot in one long video. [Proposed fix: allow a timer after motion stops to continue recording.]
2) We can capture longer events in one single video. [Proposed fix: indefinately restart any timers if noise or PIR or video motion is detected during the recording using additonal controls]
I really want 1. To be able to adjust the time it records for after the last motion/audio detection would be great
I think 2 already happens if you use the function to record until motion stops
Yeah I should have been clearer. I would want (2) if I was using a fixed record time. This is on the hardwired devices where power is no issue, I want a nice long recording, rather than multiple 2 minute ones.
Both 1&2could be served by ‘record for x minutes after last event detected’.
