Arlo Pro 2/ Echo Dot/Firestick compatible?
  • 1 Reply
  • 1020 Views
DevilsGlovk
So, I was wondering if there was a way I can control the firestick with the Echo Dot? When I talk into the fire stick remote and say Alexa show me front door. It works most of the time. Live feed shows on tv. If I had my TV on with the firestick on. Is there a way to control it with the Echo Dot? I can’t seem to figure this out. But like I said it seems to work fine with the remote from the firestick.
JessicaP
Hi @DevilsGlovk,
You can currently use the following Amazon devices with your Arlo Cameras:
  • Echo Show
  • Echo Spot
  • Fire TV (all generations)
  • Fire TV stick (2nd generation only)
  • Fire TV Edition smart TVs
You can read more about it here: How can I use Amazon devices with my Arlo cameras?
  • 1 Reply
  • 1021 Views
