Arlo Pro 2 Disabled
I am remote and disabled one of my camera's. Is there any way to add the camera back without being where my system is?
9 REPLIES 9
You can use Settingd, My Devices, your base, Restart button at the bottom. No guarantees.
I appreciate the information. The base reset up didn't see the camera.
The battery might be dead if the camera couldn't connect to the base for any reason.
I appreciate the tip but this camera is actually plugged in. I was trying to take a picture and it wouldn't take. I hit the delete camera button thinking it would reset. Unfortunately I found out it removed the camera.
Try resyncing it normally. Any luck?
Is there a different way of doing that without holding the camera up to the base?
I've been able to press the base sync button and then run to the camera to press that sync button.
Unfortunately, I'm almost 600 miles away from where I have these set up.
Anyone with phsical access to do this for you?
