Arlo Pro 2 Detection Area
  • 2190 Views
nerolave
Hello,
When I configure a detection area, Software says that If I want to use my camera as wireless, without any Power plugged, Detection area are disabled.
With previous models, we could set this Detection area without any Power adaptator. What are the reasons to disable this ery usefull feature in Battery mode? Is it a bug?
Many thanks.
Regards,
Arlo Smart zones are allowed on battery-only cameras since the zones are sensed by server post-processing, not in the camera. Normal zones must have the camera plugged in.
nerolave
Hello,
You are saying it is possible using this feature with the 3€ cost per camera addon or it is possible with the basic suscription?
Many thanks.
JessicaP
Hi @nerolave,
For zones to work when on battery, you will need the Arlo Smart feature while for normal zones to be always plugged in, that is with the basic subscription. You can read more about it here: Arlo Smart
  • 2191 Views
