Arlo Pro 2 Cannot see Feed on iPad
  • 9 Replies
  • 1251 Views
PGDen
I have 2 Arlo Pro 2 cameras.  One is inside and the other outside and both are hardwired.  They are connected to a VMB4000 base station with a USB drive and I do not have a subscription.  This has been a great system for a number of years and I really don't have a need to update.  When I updated to the latest Arlo rev on my iPad I could no longer see my Feed, though I can still see them on my iPhone.  The message I get on my iPad is--Get a plan to view video recordings and more. See a 30-day feed of recorded videos, mode changes, and other events with a plan.  How do I get back to being able to see Feeds on my iPad?  Thanks in advance for the assist
9 REPLIES 9
Is the iPad using the same Arlo Account?  Or is it set up to use a "Friend" account?
PGDen
Yes, same Arlo account.  Additionally, I do get a notice on the iPad when there is an event that triggers the camera, though I can't view it.  Hopefully you have a solution.  Thanks for the response.
Is the iPad running iOS 15 or later?
Assumng it is, then the first thing I would try is uninstalling the app on the iPad and then reinstalling it.
PGDen
Yes, currently on ios 16.3.  I deleted and reinstalled and no change.  Any other suggestions would be appreciated.
Thanks,
BrookeN
Can you please send a picture of your feed.
PGDen
PGDen
BrookeN
Can you uninstall and then reinstall the Arlo app from the Ipad and see if the library appears?
PGDen
I uninstalled and reinstalled and no change.  Same message in Feed with the rest of the screen grayed out.
  • 9 Replies
  • 1252 Views
