  • 6 Replies
  • 3217 Views
TPetrich
I have no problems with the Arlo app on my iPhone, but I cannot log into the Arlo Web Portal on my Mac.
I am running Mac OS 10.14.6 and using Chrome Version 78.0.3904.108 (Official Build) (64-bit)
@TPetrich wrote:
You are right.  I do have it on. I didn’t realize I did that. Do I have to turn it off before activating my account using my Mac?
You should be able to log in with it on.  But I suggest turning it off (at least as a test), and see if you can log in from the Mac.
6 REPLIES 6
What's the exact issue? How far do you get? Do you have 2FA enabled?
TPetrich
I do not have 2-step verification active.
When attempting to log into the portal I have tried entering the 6-digit code generated from my iPhone's app and I have also  tried tried a different verification method, entering a code emailed me.  In both cases the "processing circle" simply keeps spinning.  I've left it like this for 30 minutes and it does not stop.
The funny thing is, as this is happening the app on my phone states that I have been logged out of the Arlo app as I have logged in on another device.
This sure sounds like you do have 2-step verification enabled.
TPetrich
Stephen,
TPetrich
I was finally able to login on my Mac, once I turned off 2 Factor Auth.
Thank you
  • 6 Replies
  • 3218 Views
