Arlo Pro 2 Camera with Blurry Images - Lens not clear and smooth
Over the years, this one Pro 2 camera that's been mounted to a tree facing South, the video images have become increasingly blurry. At first I thought something may have gotten stuck to the camera lens. Last battery change I cleaned off the lens and no change. Have taken the camera down and replaced with an Ultra. After looking closer at the lens, it appears to have become cloudy and crystalizing. Not smooth and clear. Has anyone had any success replacing the camera lens assembly or is this camera for parts now? Thanks.
There is no replacement parts from arlo that would allow you to replace just the lens.
I know that trees excrete resins into the air so it might be this that has blurred the lens. The dried resin would also be difficult to remove abrasively so you might want to try using a solvent to remove the buildup.
Some have posted similar issues here after long term exposure to direct sunlight, again not recoverable.
Thanks. That makes sense. I'll give that a try and report back.......
So I tried removing the tree resin with 70% alcohol, and it just seemed to smear it around some. Image is still blurry. Question.....is the camera lens glass or polycarbonate?
There is little detail on the lens product used by arlo, best answers suggest plastic with a hardened coating.
https://community.arlo.com/t5/Arlo-Pro/Arlo-Pro-Lens-Deterioration/td-p/1860636
https://community.arlo.com/t5/Arlo-Ultra/Soft-Glass-on-Lens/td-p/1697159
https://community.arlo.com/t5/Arlo-Ultra/Arlo-ultra-spare-parts/td-p/1742330
I will tag a moderator in case they have any insight. @JamesC @ShayneS
All good threads, thank you!
At the moment, I'm thinking of just chalking it up to the exposure of the suns harsh UV rays, seeing the lens can't be cleaned and it appears that if there is a lens coating, it's coming off, which is causing the blurring.
All of my camera's are Arlo Pro. I have had them for at least 6 years. The only time I've had foggy or blurry lenses was when tree sap would run in late summer and I would clean them with a simple soapy solution. I've avoided some of the lense cleaners because they would be to caustic to the lenses causing little fractures. I learned that mistake from cleaning headlights of my truck. Direct sunlight not so bad, but combined with lense cleaner, it's a cause for blurry video.
It's been my experience that solvents can damage even the surface you're trying to clean off, but instead I've a soapy dish soap and a soft cloth and patiently clean the surface of the lense without cross contamination of debris entering the lense area. Even if you use the solvent, you've got to clean the solvent residue off to prevent the sunlight from crystalizing the lense. Good luck.
Soapy dish soap, soft cloth and patience is the better solution.
Gave it a good cleaning with soapy water........to no avail. I'll try and find one "for parts only" on eBay with a good clear lens and swap out. Thanks for all the replies.
