Arlo Pro 2 - Camera issue (just one camera). Begins recording every 5-10 mins but no motion.
Hello - I recently purchased an Arlo Pro 2 system and I am having trouble with one camera. All three cameras are operating wireless and are mounted outside. The camera I am having trouble with is on my deck, it begins recording around 11AM and continues every 5-10 minutes with recoding and there is no motion on the video. I turned the sensitivity to 1-2 and still it continues during the 11AM - 4PM time. I moved the camera twice and still constant recording during this time.
Today, I moved the camera inside and the same thing occured, just not as often. No issues with the other two camers.
I could use some help
Do you have scheduled recording set in the app for that camera?
How do you check?
@Dbecker88 wrote:
How do you check?
Under "Mode" in the app
Yes scheduling is turned on for all cameras
Possibly turn that off, and try just armed?
Hi Dbecker88,
Could you provide a screenshot that shows the error you're receiving?
As idbl_fanatic1 mentioned, have you tried using the default "Armed" mode to see if the recording is working when motion is detected?
