Arlo Pro 2 Camera Stuck Offline
Have 2 Arlo pro cameras. One of them just constantly goes off line, other works a dream. Faulty one it stays offline now. Have 4 other cameras, no problems.Just this one, tried everything, used to work ok,then just started to keep saying offline..
.Tried everything, taking battery out 24 hrs, factory reset, swap battery round. It's 2 months old, want send it back,replace it,as it's a useless brick. Spent hrs,trying to fix this. Any advice please.
Have you previously contacted customer support regarding this issue?
Have you swap cameras around to see if it's the camera or the location?
