Arlo Pro 2 Camera Is Not Picking Up Movement In My Driveway
I just got the 4 camera set a few days ago, picked up 2 suction cup mounts so I could figure out where to set them up. I have this one mounted on the 2nd floor window facing the drive way, I had to position the camera so it could not see the road because it kept going off (motion not audio) but we have left the drive way and came home and the camera has not triggered, I have walked up and jumped up and down and nothing. I even went as far as swapping out cameras so I know it's not a defective camera.
Alot of us are having the same problem you are including me, they changed something on there end and we will have to live with it until they fix it. They were having rapid battery drain issues (I wasnt) and now it appears they fixed it from other post but now we have this problem because I think they cut down on the sensitivity for the cameras to save the battery and now were stuck with this.
The camera positioning is less than optimal for best detection which is across the FOV. Also, have you tried increasing the motion sensitivity in your modes and rules>
Yes I have motion set at 100%, and I did read shortly after posting this about the FOV, and if I had known that about these cameras I would have went with w different kind. Most of my spots I need to view are FOV.
What is FOV ?
FOV is field of view
And also just to make sure, the cameras are mounte OUTSIDE the windows, not inside ( as the cams will not detect thru most glass )
Yes they are mounted outside, and the funny thing is, today that have gone off so far like they should. .....IDK ?
There was a small outage at the far end re signing on ( main page notice ) ... maybe it had a related effect.
Good to hear it's workning now
I have the same issue with one i installed yesterday!
it does not seem to have any night vision either! Do we need them to be wired to be working properly?
