Arlo Pro 2 Camera Fogs Up Overnight
one of my cameras fogs up overnight it is fine during the day, I have 2 cameras in the same location, the other one is under the eaves and doesn't fog up, the one that does fog up is attached to the barge board and in the open
I have attached photos taken at the same time from each camera, I have changed cameras around, and the one that is on the barge board and in the open always has this issue. Any one else have this issue
Nothing much you can do about condensation other than to try a different location or maybe wipe the lens with a bit of anti-fog solution.
thanks, has anyone used anti fog solutions, just checking before I do in case there is a possibbility of damaging the lens
While I haven't used it, others here have with success. Just put a drop or two on a clean lint-free cloth and carefully wipe the lens. Don't apply the solution to the lens directly.
A little dab of RainX or similar on a clean cloth that wipes the lens carefully may help.
