Arlo Pro 2 Blinking Blue Light. Camera is closest to the Base Station.
  • 1 Reply
  • 666 Views
DLaden
I have a Arlo Pro 2 camera that is connected the base station.  The app shows the camera has a full charge and charging.  The option to disable the led when charged is unchecked.   I happen to look at it today at night and I see the red night lights and a fast blinking blue light.  It seems to fast blink for a second then is off for half second then repeats.
Have 5 cameras online.  This is the only one showing the blinking blue light.  This is the closest camera to the base station.
Reading online...this is what i should see for syncing?  What is syncing?  I am able to interact with the camera and get live feed from it.  It records action when action is seen.
What have a clue what my cause may be? Annoyed more lights are on that need to be.
Dannybear
Could I suggest that you try toggle the led settings to see if that behaves correctly.
Also remove and reseat battery and external power if connected to see if comes good.
  • 1 Reply
  • 667 Views
