My Arlo Pro 2 base station (multi LED version) is offline and the power led is Amber. When I have done a hard reset, there are flashing green lights but then only the power LED lights up amber. Please help!!!
How long has the power light been amber?
If your getting the offline base station firmware issue and have a USB backup device installed it can take up to a few hours to become normal.
With no USB then it can take up to 30mins. If the earlier then you may have to resync the camera’s again.
This is based on my unique experience.
Hi, I have exactly the same problem with my base station. I hope that some one can help.
It’s a bit like pushing crap up a hill every day I admit. I am battling this twice daily.
Hi, today 24h later still only power led solid amber.
I have tried removing the bas from Arlo app and adding as new but it is not found.
I did also try the reset button on the back of the basstation with no success.
My basstation is the one with 3 led power, internet and camera. Only power led is solid amber the other ones does not have any lights.
If I check my router I can for short periods see that it connects and get ip address but I see the MAC address as 00:FF:FF:FF:FF:FF and this does not look right to me.
For short periods every now and then the light goes all green on power and amber on internet but it only stays for a second or two then back to only power solid amber.
I sadly think my bassatation is broken.
Hi, I have no luck with the reset button, pressed the button 10 sec end 60 sec no difference.
I gave in and ordered a new Ulta SmartBase station. Now I hope it will give me a solid system.
Thanks for the replys
