Arlo Pro 2 (6) Camera System Setup Help
I both a 6 camera arlo pro 2 with the base. Does NOT make sense the Arlo base can only connect to 5 camera? I'm being obligated to have a subscription. Is it really how this work? I could have gotten a 4 Arlo pro 2 camera plus base and bought an extra Arlo pro2 camera instead.... Arlo should be properly labeled on the box that only 5 of 6 camera will be allowed to be connected for free.
Did you follow the directions completely and accurately? You need to use a new account with the proper model number selected in either the US or Canada to use all 6 cameras from the 6 camera set in one login.
