Arlo Pro 2 20-30 seconds notification lag
Seems like 20 to 30 seconds can go by before I get a notifaction that someone was at my front door. Most of the time they are gone by the time I even get the notice.
Is there a way to speed it up?
If you subscribe to Smart, move the camera to deactivated in Smart.
I do not subscribe to anything for the cameras.
Hi @sdmtnbiker,
Try to reboot your Base Station to see if that helps with the notification delay. And try to see if you're experiencing this issue when you're on WiFi or cellular data on your phone.
