Arlo Plan modes help
  • 1 Reply
  • 936 Views
bowman123
Hi
I upgraded my app about 6 months ago (everything was working fine before the upgrade)
I have a schedule which is arm at 8pm and disarm at 8 am
I have home and home away set up so that when I am home the property is in standby and when I leave it is armed
Once the schedule has activated, the home and home away  doesn't  change over, yet if i select it and select test , it changes to the mode.
it does change from the home mode to the schedule mode.
I have been fighting this for 6 months and getting a bit pissed.
Everything worked fine before the upgrade.
I have two locations and neither will work properly
What is the correct set up procedure for  what I want to achieve
Paul
Best answers
  • StephenB
    @bowman123 wrote:
    Hi
    Can you post screenshots of the schedule and geofencing automations for one of the locations?
    (maybe mask out the text on the geofencing map).
@bowman123 wrote:
Hi
  • 1 Reply
  • 937 Views
