Arlo New App won't discover device
  • 1 Reply
  • 1172 Views
rug92901
Arlo New App is atrocious, and the troubleshooting support is even worse.  For an expensive system, it is unacceptable.
Spending hours trying to get my phone to discover Arlo devices for hours to no avail. Tried everything....deleted app. re-installed.  Reset base device multiple times.  Reset router multiple times.  followed every troubleshooting step documented.
Should not be this difficult- especially when forced off an app that was working just fine
ShayneS
Hi @rug92901
Did you perform a factory rest on the base station or did you just reboot it?
  • 1 Reply
  • 1173 Views
