Arlo Netgear Pro 2 VMS4330P-100EUS
  • 1 Reply
  • 1053 Views
  • 2 Likes
Isy
Hi...I don´t see anywhere for the Arlo Pro 2 the distance coverage, or if the is night vision.  Could someone please clarify.
Thanks,
Isabel
What distance coverage - WiFi or person detection? WiFi is up to 300 feet (100m) but will be limited to much less than that in normal usage (50-100 feet is typical).  Motion dtection is up to 25 feet if well positioned to catch motion (motion across the field of view, not at the camera).
Because these are battery-operated cameras, the night vision IR illuminators only get decent coverage to 15-20 feet. If you need more, you'll need to provide external lighting of some sort.
  • 1 Reply
  • 1054 Views
  • 2 Likes
