Arlo Charger Gives Charging Error
"The charging source connected to the camera cannot charge your battery. Please use the power adapter designed for your camera." with an "OK, got it" button.
The problem is I am using the Arlo charger and cable that came with the camera.
Do I need to return this as defective?
gilbep01,
Do you have another camera you can test the charging cable with to isolate this further?
