Arlo Camera Mount for Drain Pipe?
I have a four camera Arlo Pro 2 system, and have used the external mount to fix the cameras to my wall, by drilling into the wall. While I was installing the cameras, I thought that it would be a good idea if a mount was available that would clamp onto a drainpipe / downpipe (see photo). I searched on Google but couldn't find anything, so does anyone know if such a thing exists ? I was convinced there must be something available, but I can't find it.
Can I attach the camera to the drainpipe instead ?
The picture hasn't been approved yet, but could you either drill holes into an automobile hose clamp and attach the camera mount to that and tighten the clamp around the drain pipe or use some long cable ties and feed them through the screw holes in the mount?
Brian
Thanks for the reply. Yes, I thought about trying to make something myself, but also thought there must be something available off the shelf, and was surprised when I couldn't find anything.
I'm sure I've seen one before for a different camera system but can't for the life of me find it now
