Arlo Camera Keeps Saying wrong Time
Ok, I completely reset my base and all 5 cameras, because 1 outside wouldn't record motion /or did it at sporadic hours. SO after the reset a completely different camera is now doing it.
I have them on the same schedule, 4 camera's will say (##minutes ago) but the single camera Will only show the day before, every time.
Are you using a mobile App or web browser?
Can you live view the problem camera?
If not, can you access the camera’s video settings and see if the thumbnail updates. Then check live view again.
