Arlo Base offline after setting up Eero 6 network. Shows all 3 green lights.
  • 1 Reply
  • 1146 Views
Arlo_user117
Hi,
Just switched my network from an Arris modem/router to the Eero 6 mesh setup. Base won't connect and shows offline on Arlo web and app. Connected base using ethernet cable direct to Eero 6 and Arlo base shows 3 green lights (power, internet, and cameras).
I've tried power cycling Arlo base already.  Ethernet cable does work on other devices when connected to Eero (shouldn't be an issue since internet light on Arlo is green anyways).
I understand individual cameras won't be able to take advantage of mesh network as they all connect to the base.  Need to get Arlo system back up and get this base working again.  Any suggestions?  I'll remove device and try to connect again as a final option.  Thanks
michaelkenward
Sensei Sensei
Sensei
It isn't clear to me from your description if your various moves included doing a complete factory reset on the Arlo VMB4000.
The hub is now talking to a different network and may have to forget any bad habits, or settings, that it picked up from your previous modem/router.
Power cycling is not severe enough to clear those settings.
See the bit in the manual Reset a Base Station to factory settings.
Find the manual here:
Document Library
Just another user
  • 1 Reply
  • 1147 Views
