Arlo Base VMB 4500 Arlo Pro 2
  • 1 Reply
  • 756 Views
TimmH
Having issues with my VMB 4500 going off line a lot, most of the time,.
Problem started shortly after the addition of a wired security light/Camera and essential Doorbell camera.
My system updated the software and now it's like nothing worked with my Base?
Any advice for a solution would be welcomed.
BrookeN
You can try doing a reset of your modem to see if that helps. If not, you can also reset the basestation. Please keep in mind if you reset the basestation you will need to add the cameras to the basestation again.
https://kb.arlo.com/1057976/How-can-I-factory-reset-my-Arlo-SmartHub-or-Base-Station
BrookeN
  • 1 Reply
  • 757 Views
