I recently bought an Arlo 2 with a single camera. Everything was fine for a week or so until I tried to set up geofencing today. In the Android app, whenever I try to select the geofencing mode or click the pencil icon to edit geofencing settings the app crashes With the message 'Arlo has stopped'.
I have tried reinstalling the app. I have also reset the hub (losing all settings and the connection to the camera), but nothing has fixed it.
I am on Android 8.
Has anybody else encountered this?
This issue is now fixed on the latest Arlo Android app version, which is version 2.16. Make sure to update to the latest version and you can read more about the update here: Arlo Android App - 2.16 - 29th April 2020
I have the newest Arlo app for Android.
Since the last update, the app sometimes crashes when I open the app. This occurs on multiple Android devices I have. The last 3 of 4 updates for Android made the app worse. The version I had in let’s say end of last year was bug free for me on Android. Now we have had notification problems and app crashes.
Also since yesterday, when I open the mode tab and press the edit pencil of geofencing the app crashes. No information is given by Arlo about any known issue. However I read that Life360 gave a statement about a bug in apps that use google maps/location. Is this the problem for Arlo as well?
Hey PolaxMan and TKNT81,
What phone device are you using? Have you tried restarting your Android device to see if that helps?
Yes, I did unistall the arlo app
Cleared cache of the arlo app
Restarted my Android 10 phone (OnePlus 7T Pro)
Re-installed the Arlo App for Android
all without succes.
Arlo, have a look at Twitter and then Life360, there seems to be a problem with in-app use of Google’s location service. Is this also the problem for Arlo?
My two phones, OnePlus and Blackberry all have the same issue.
Life360
Arlo
Garmin Connect
when acces is required of the in-app location the app crashes
Life360 stated via Twitter that there is a problem with Google’s location service.
Life360 and Google are working to fix it!
They gave a workaround:
Clear cache AND data!
Then login the Arlo app and this worked for me!
24 hours ago Life360 gave a statement on Twitter that they were aware of an issue. Arlo status: all up and running
Why isn’t Arlo giving timely statements?
They just did in the post prior to yours about a half hour before u posted
But what I meant, this statement was rather late!
