Argo Pro 2 base station power
  • 2 Replies
  • 2680 Views
Tripoli
I have 1 story house and recently put up 4 Parlo Pro 2 cameras.  I have moved my Base Station three times trying to get a gppd signal to all of my cameras.  Each time i move the base it affects different cameras on singal strength.  I have also moved one of my problems cameras but still only one bar at the best.  I have gret wifi signal with Cox cable.  I have tried a wifi extenter but that still does not improve the power of the base station to reach all my cameras.  Is there a slouation? or is the only remdie to buy another base station?  Thanks john
steve_t
Master Master
Correct. If the cameras are so far apart that they are not performing well, you'll will need another base station. In saying this, I have a camera with only 1 bar of signal strength and it works perfectly.
A wifi range extender won't do anything for Arlo except allow you to place a base station further away from your router and connect the base station via the required ethernet connection
Tripoli
Thanks very much.  Mine are working well also but was just looking for an answer to make sure I was not missing anything.  I have tried several different positions of the base station and think I have found the best for all 4 cameras.  John
  • 2 Replies
  • 2681 Views
