App showing all cameras offline
When I open the app to enable the alarm, the cameras appear offline but if I try to select a camera and press play button I can see it without issue.
This issue is present on both Arlo Pro 2 cameras and also on the VMC3050r6 camera.
I've already tried to turn off and on the system without solutions.
Best regards
Orlando
Can you try removing and reinstalling the Arlo app?
Hi,
I can try but the problem We have this issue on 3 different devices and 3 different accounts!
We tried to uninstall and install the app from scratch on two different iphone but we still have the issue: we can play Cameras but we cannot activate the alarm because the system is offline!
please help us
It's been suggested on here that removing and re-adding cameras helped some users. You could try with one to see if you're successful.
Are you using a "Friend" account?
If so, there is a bug here that Arlo is still investigating. The only workaround right now is to use the primary account when you log in.
Hi to all,
I'm using 3 friends account but I've also the problem with my Primary account.
HI,
Are we still experiencing this symptom?
