Any way to chain link cameras?
  • 1 Reply
  • 1125 Views
jkmail
I try to make 4 or 5 cameras record when one sinces motion but only 2 or 3 will record. Is there a limit to this ?
It use to work quite well ( linked cams)... And it did work for a number of cameras too.
But, back about a yr or so , the FW changed and the linked cams stopped working as well as they use to.
If you do a good search back, you may find the threads.. It was never cleared up as to why.
  • 1 Reply
  • 1126 Views
