Adobe Flash Player Settings
  • 2289 Views
45Frank
When I try to look at my cameras on my PC I get a message across the camera that asks to allow Netgear.com local storage, Allow or Deny. No matter what I do it will not go away so I can't view the camera.
Any Help?
Try Fire Fox browser (seems to work the best )
45Frank
That's what I use now. I will check a few other brousers.
Your error message sounds like it's coming from Flash itself. Since Flash is an add-on for FF, I suspect that's the issue.  remval and reinstall of Flash may be needed although you can check the control panel for Flash to see if that helps.
I use Chrome almost exclusively. The issue with Chrome and Edge is that every time you start the browser up you get a Flash warning message and you need to click on the "click here" link to get the pop-up to allow Flash to run. I use sleep for the computer and never close down Chrome so don't often have to do this.
  • 2289 Views
