I have 2 cameras, arlo2, they used to work well past 2 years...THEN problems with Adobe Flash Drive. I actually have to log in twice to view cameras or recordings. God for bid something wrong/bad was happening at my house, it would take me 5 minutes or more to log in!?!
Spoke with 24/7 'Tech Support, no one seems to speak good English..when said and done, the tech girl gave an 800 number to call....it was for the Geek Squad at Best Buy \0/ WOW
I would NEVER recommend these cameras.
@jpry1 wrote:
Chrome 77 on 8.1 Windows,
@StephenB i see now where Chrome and Firefox do not allow Flash as a default, how do I get around that?
thanks,
With Chrome, you click on the padlock right next to the URL (my.arlo.com) right after you log in. You'll see a pop-up that lets you allow flash. Do that, and you'll see a "reload" button appear at the top of the page. Click that.
After the reload, you will need to log in again. But flash will work.
The "allow flash" is moderately sticky - I don't need to re-do it every single time I log in.
What exactly is the issue you are experiencing? is this with the web browser & the flash player?
A newer version Flash is required. I get this all the time now, and yes I have downloaded newer version. I have to accept and sign back in...its annoying and to have the ARLO tech people come back and say call this 800 number...the geek squad at Best Buy....doesn't give me a warm and fuzzy
tried pasting pic to no avail,
What browser are you using?
Thanks, Chrome 77 on 8.1 Windows
thanks,
thanks,
Thanks, its kind of pain but least my cell phone phone works fine
@jpry1 wrote:
... its kind of pain ...
Agreed. Though less of a pain than the steps needed with FireFox or Edge.
There's a similar Firefox trick to the chrome one suggested by @StephenB.
Up to the left of the "address" windows there is a row of icons. The "lego" brick is "Manage plug-in use". Click it and allow flash.
Unlike Chrome, it seems, this isn't sticky.
Just another user
