ARLO pro 2 and ARLO secure 4.11.1 update
  • 4 Replies
  • 2523 Views
Ashakijohnson
Hello.Friday January 12, 2024,  My iPhone updated to the new ARLO home security app 4.11.1. Since the update, I haven’t received any notifications for any of my ARLO Pro 2 cameras. My base is VMB4000r3.
i checked my activity zones. My cameras are charged and listed on my phone but they are not recording anything.
I have restarted my devices AND I have checked for firmware updates, there are none. This is frustrating.
help, please. thank you.
DannyBearAgain
It would appear that you have a unusual issue,
My pro2 setup is similar with 4 cameras but I am using a much earlier app version as I suspect arlo is silently depreciating features based on their EOL policy.
Your next step would be to scrub your system from the arlo account and setup again as new.
Warning: Do not delete the arlo account as you will loose the library UI version and have it replaced with the newer feed UI that everyone now curses.
Go into the app, remove each camera then the base station last.
Use a paper clip to factory reset the base station. Hold the internal reset button for 12 sec or until the base LEDs begin flashing. The led configuration should eventually settle as green, green, Amber, left to right.
Use the app to add the base and cameras again as new.
 If you have difficulty adding back try using a pc connected to the local router and login to my.arlo.com website.
Adding arlo devices requires the mobile device to be connected to the local wifi and will fail if using cellular data.
DannyBearAgain
To determine if you have working cloud storage, make a manual recording and confirm that you can view it in your library.
Check what mode is selected in the app. The armed mode should have a camera rule embedded for the active cameras.
Check the camera motion detector is working, use the motion test utility within the camera settings menu.
To reset the camera, pull the battery for ten seconds.
To reset the base, power cycle.
Ashakijohnson
Hello:
I completed the following:
  • completed manual recording and was able to view it.
  • my ARLO is set to Armed.
  • I checked motion for all cameras.
  • I also checked activity zones, motion detection and audio detection.
  • I have everything on the highest setting just to see if my cameras will work.
  • All ARLO pro 2 cameras have been reset and so has base station VMB4000r3
Nothing is working. Did ARLO discontinue service to ARLO 2 cameras on this update? That is the only thing I can think of that could cause this issue.
Thank you.
DannyBearAgain
Ashakijohnson
Thank you Danny!
  • 4 Replies
  • 2524 Views
